When I turn on the turn signal (left or right) it "sometimes" flashes rapidly for 5 - 10 and slows to a seemingly steady pace. Why?
Feb 10, 2008 at 8:34 AM
DOCHAGERTY
CERTIFIED EXPERT
The ground wire in the tail light assemblies is the problem. Remove the connectors and inspect the brown wire and the connection in the tail lamp assemblies. I have repaired these with success and sometimes replacement of the wiring connector or hard wiring the brown ground wire to the ground bus will do the trick, send me your e-mail address in a PM and I will try to talk you through this repair.
