1997 BMW 325 Alarm/Battery
1997 BMW 325
KIRBYK
Computer problem
1997 BMW 325 V8 Two Wheel Drive Automatic
Dear representative,
We had our BMW in storage and during that time, the battery went dead. I replaced it and when I tried to re-connect the battery cables, the alarm system starts ringing. I believe this is a factory system.
I've tried to open the driver side door with the key while the alarm is activated but that didn't seem to de-activate the alarm.
Any ideas on how I can connect my battery cables without the alarm instantly getting activated?
I've called the local BMW shop and they want $180.00 just to plug in the diagnostic equipment, not including any parts.
HELP...
Thanks,
Kirby
Mar 21, 2009 at 6:14 PM
DOCHAGERTY
  • 9,603 POSTS
The stock BMW alarm is located under the glove box, in the kick panel below the `box. Locate it and disconnect it. Then it might reinitialize.
Mar 22, 2009 at 10:22 AM
KIRBYK
Thanks for the tip.
I did locate (2) modules, the first module (about the size of a pack of cigarettes) had a blue color wire connector plug. The second (which was higher up towards the top of the dash) had a yellow connector. both connectors contained about 20 wires.
The problem with both is that I wasn't able to slide either of the modules out of their cradle nor dis-engage the connector wire cable. The space to work with is very limited.
Any other suggestions? Could I disconnect the horn from inside the engine compartment?
I now have a new battery installed but every time I try to connect the battery cables, the alarm starts to sound.
Thanks,
Kirby
Mar 31, 2009 at 8:35 PM
