1995 BMW 325 cooling system light
1995 BMW 325
167,000 MILES • 6 CYL • 2WD • MANUAL
THE3BEEZ
I have recently had to replace the thermostat because it was sticking, causing my gauge to register hot. I also had my ac belt changed and my cooling system sensor changed. They said that it held good pressure and that it runs good. Now, all of a sudden my cooling system light that says check owners manual has come back on. What should I do next? They said nothing is seriously wrong but I want that light off.
Dec 29, 2008 at 11:35 AM
DOCHAGERTY
  • 9,603 POSTS
If the low coolant warning is on and the coolant is not low then the coolant level sensor is faulty and should be replaced.
Dec 29, 2008 at 11:51 AM
THE3BEEZ
The light doesn't say it is low, it says check coolant system see owners manual. Is this what you mean?
Dec 29, 2008 at 4:50 PM
DOCHAGERTY
  • 9,603 POSTS
Yes, the coolant level switch is bad and needs replacement.
Dec 29, 2008 at 6:49 PM
