I have a 1995 BMW 325is that needs a new cylinder head gasket. As a result, I need to remove the cam sprockets to allow removal of the cylinder head. My question is concerning the 4 bolts/screws that hold the cam sprockets onto the cams. They are an unusual bolt/screw. Is there a special tool needed to remove those bolts/screws? If that special tool cannot be obtained, is there an alternative method to remove them?
Thank you very much for any help you can give!
Larry Eller
[email protected]
Larry Eller
[email protected]
Jan 14, 2009 at 1:39 AM
