It is located behind and to the left of the glovebox. It is usually easier to remove the glovebox to access the filter. There is a plastic cover that has a Torx screw at the bottom and a lever at the top, remove the screw and rotate the handle to remove the cover and you will then be able to access the filter.
Jun 8, 2008 at 12:04 PM
