1993 BMW 325 Tachometer will not read RPM's (sticky tach)
1993 BMW 325
SPIRITOF77
Computer problem
1993 BMW 325 6 cyl Two Wheel Drive Automatic 116xxx miles
Hey, my BMW has a tachometer that will not register correct RPS's. it is as if it gets stuck and then when I reach a higher RPM level it jumps to it. If I am going at 2000 rpms, it will show 1000 rpms until 5000 rpms where it will jump to ad stay there till i come back down to 200 rpms.
It might be a stuck spedo cable and need penetrating oil or replacement?
Aug 19, 2008 at 5:17 AM
DOCHAGERTY
  • 9,603 POSTS
There is no cable, it is all electronic. It may be a mechanical issue or it may be the cluster will need replacement.
Aug 19, 2008 at 9:12 AM
SPIRITOF77
oooh, I am used to working on much older cars, so the electronic tach would make things a bit more complicated.
is there anywhere specific that i should look to take it, or just my local bmw dealership
Aug 19, 2008 at 11:36 AM
DOCHAGERTY
  • 9,603 POSTS
Look in the Yellow pages for a local speedo/tach shop before you sacrifice your $$$ at the dealer.
Aug 19, 2008 at 2:22 PM
DOCHAGERTY
  • 9,603 POSTS
Look in the Yellow pages for a local speedo/tach shop before you sacrifice your $$$ at the dealer. Or call 619-444-2290 and talk to John and\or Sean @ Autobahn Dismantling.
SPIRITOF77
thank you very much, i am going to look at several local places in orange county
Aug 21, 2008 at 11:24 PM
