1990 BMW 325 fuel injection system
1990 BMW 325
250,000 MILES • 6 CYL • 2WD • MANUAL
SOULWINAIRE
How do you determine if injectors need replacement?
Car ran fine, then bought some fuel during real cold spell (below 32*), and car has not run right since. Took out fuel pump, cleaned screen, car ran sort of fine for a while, but now pump is howling, and it seems as though it is starving to some degree. Ran fuel cleaner through system: Lucas Bros. and it seemde to improve, but not complete. Replaced filter last year (20,000 ago).
Jan 19, 2009 at 2:28 PM
DOCHAGERTY
  • 9,603 POSTS
At that mileage, have you considered replacement of the fuel pump? I would. ♥
Jan 19, 2009 at 4:33 PM
SOULWINAIRE
Greetings,
Thanks for taking time out to reply.
Yes I have considered it. As the one in the car now is howling. Yet, I wonder, if the injectors may need to be replaced too.
The pump started getting louder when I used some fuels that had invigorate in them (alcohol). The dealership said to use Shell, in our area and forcefully said do not use the fuel with invigorate in it, nor the local mom and pop fuels. My brother has a x5, and when he first got his truck the dealer let the fuel get too low. When we somehow got it to the gas station, fueled it, it began to make howling sounds and ran badly. He too switched fuels, and this is what made me ask is it the injectors as they sometimes act funny if contanimates get past the checs and balances and make it to them.
Jan 22, 2009 at 4:27 PM
DOCHAGERTY
  • 9,603 POSTS
Cleaning, rather then replacement(they're expensive those injectors!) would be something I would try before replacing six injectors. Have you tried removal of the fuel rail and inspection of the spray patterns? There is also a possibility of crud built up in the intake plenum and perhaps around the injectors themselves. And replace that fuel pump so it does not strand you somewhere waiting for the tow truck. ♥
Jan 22, 2009 at 6:29 PM
