1989 BMW 325 Problems For Days
1989 BMW 325
117,540 MILES • 6 CYL • 2WD • MANUAL
SAMPSON001
  • 4 POSTS
Just recently bought BMW but have had a lot of problems with it. First this is what I have already replaced. Fuel Filter, Fuel Pump, Distributor and Rotar, Spark Plugs, Battery, Timing Chain, Water Pump. Now the problem with the car is that my SI board shows that my brake, rear, lic plt lights are all out but they are not. Second problem is that was going down the road at about 90mph and the car shut of as if were not getting any gas. I started to get over and as I punched the gas down the cars turbo caught and I took off. What I've found is a ground problem under steering column fixed that and found a severed wire in trunk fixed that and NOTHING CHANGED. Am going to replace Idle Control Valve But after that I'm lost. Please any suggestions.
May 16, 2008 at 8:01 AM
DOCHAGERTY
  • 9,603 POSTS
Do you have a repair manual?
May 20, 2008 at 1:11 AM
