Engine Mechanical problem
1989 BMW 325 6 cyl Two Wheel Drive Automatic
Have oil from my intake manifold into my air mass meter boot, then into my air filter. Car codes say have wide open throttle switch, just replaced it less than a month ago. Here are all the codes the car flashed from smash test. 1123,3112,3311,2331,1233. This all means very little to me because if the ECU is bad then the codes are bogus. So my question really is can you disconnect the ECU and bypass the air mass meter. If not does anyone want to buy a 325I BMW. The engine is tops but have had so many problems with it I'm over it.
Aug 13, 2008 at 9:50 AM
