Electrical problem
1986 BMW 325 Two Wheel Drive Manual
Here you go:
LEFT TURN FLASHER BLINKS FAST NO LIGHTS FRONT OR BACK LEFT SIDE
Hazards work fine
Right signal works fine
Left Bulbs good
Rear Left Assembly good switched with right
Tested Signal Switch in column Continuity with Power off Left Switch pins. Right produces same so switch appears to be functional - according to tests
Common ground used for rear hazards at front and back I believe
at least this what wiring digram reflects
The hazards bypass flasher switch because they are powered all time - and/so lights work
Any thoughts?
Here you go:
Hazards work fine
Left Bulbs good
Any thoughts?
Apr 20, 2008 at 12:03 PM
