1986 BMW 325 BMW causes
1986 BMW 325
20,000 MILES • 6 CYL • 2WD • MANUAL
CINDY HART
My car is flooding out,putting black smoke out the tailpipe, wont't idle, and dies. What do you think the problem is? No one seems to know what the problem is. Please help. Cindy Hart
Mar 31, 2010 at 12:15 PM
DOCHAGERTY
  • 9,603 POSTS
Send me the VIN so I can ID the car.
Apr 1, 2010 at 3:28 PM
DR LOOT
  • 2,311 POSTS
[quote:53e0b6ec0a="Cindy Hart"]Engine Performance problem
1986 BMW 325 6 cyl Two Wheel Drive Manual 200,00 miles
My car is flooding out,putting black smoke out the tailpipe, wont't idle, and dies. What do you think the problem is? No one seems to know what the problem is. Please help. Cindy Hart[/quote:53e0b6ec0a]
I've seen this problem caused by a bad coolant temperature sender. Your car has two of them. One runs the gauge in the instrument cluster; the other tells the computer what the temperature of the coolant is. When that one goes bad, the computer thinks that the car is operating in the arctic and it tries to compensate by making the mixture as rich as possible.
I've also seen the problem caused by an malfunctioning injector that is dumping unrestricted amounts of fuel into the engine. You can usually tell which one is bad by listening to it click with a stethoscope. A soft click means it's not closing properly.
Good Luck
Dr Loot's Assistant
Apr 4, 2010 at 6:54 PM
