1985 BMW 325 no check engine light on
1985 BMW 325
94,842 MILES • 6 CYL • 2WD • MANUAL
LLOYDEE
  • 4 POSTS
without the ckeck engine on.i have no power to the distribitor nor do my fuel pump come on .so what do i do to correct this problem.
Mar 12, 2009 at 9:11 PM
LLOYDEE
  • 4 POSTS
[quote:0298d9e6f2="lloydee"]Electrical problem
1985 BMW 325 6 cyl Two Wheel Drive Manual 94842 miles
without the ckeck engine on.i have no power to the distribitor nor do my fuel pump come on .so what do i do to correct this problem.[/quote:0298d9e6f2]
Mar 12, 2009 at 9:14 PM
LLOYDEE
  • 4 POSTS
BUY A REPAIRE MANUAL.I COULD HAVE DONE THAT,BUT WAS LOOKING FOR A FAST ANSWER I DONT THINK YOU ANSWER WAS WORTH MY 15.00 DOLLARS.BUY A REPAIR MANUAL.YOU GOT TO BE JOKING 15.00 TO TELL ME THAT. VERY UNHAPPY WITH YOUR ANSWER.
Mar 12, 2009 at 9:56 PM
DOCHAGERTY
  • 9,603 POSTS
Check the fuses and inspect/replace the main and fuel pump relays and see if there is power from the battery to these relays.
Mar 12, 2009 at 9:57 PM
LLOYDEE
  • 4 POSTS
THANKS FOR YOU REPLY.THAT WAS BETTER THAN THE FRIST REPLY[BUY A REPAIR MANUAL] KNOW ONE MORE QUESTION. WHERE WOULD I START TO FINE THAT MAIN ENGINE RELAY,
Mar 12, 2009 at 10:04 PM
DOCHAGERTY
  • 9,603 POSTS
It is located next to the fuse box. The main relay is probably a metal case(as opposed to a plastic case for replacement relays) and is about 30mm x 30mm square. The fuel pump has a green wire with a purple stripe coming from terminal 87.
Mar 12, 2009 at 10:21 PM
