My car shifts hard but stops after 10 minutes.... but comes back whenever i stop at somewhere and drive the car again..... sometimes when i go to work in the morning it shifts hard all the way to work...but on my way home it stops shifting hard... i took the car to get the codes read...
and i have: Electrical thermostat fault...
bank 2 control deviation....
misfire cylinder 5...
crankshaft position sensor...
segment measure engine...
ignition circuit zk4 side front left...
ignition circuit zk8 head front left...
ignition circuit zk10 battery unplug1....
internal ecu error...
94 can: incorrect data from dme....
ce ambient air temperature...
thermal oil level sensor...
the tcm could not be read... took it to an electric and said it has all signals but it will not get read... i also have an alarm badly installed since lights dont come up whenever i lock or unlock the car... or even when alarm goes off.... could it be the problem??? or could one of the fault codes be the problem to the hard shifting or tcm?
Mar 23, 2010 at 9:20 PM
