On a cold morning at about 30 degrees, I start car,put in drive and sometimes reverse,the car does not want to go and will spit transmission fluid out. when you shut engine off and restart it then seems to be ok. This is a gm transmission built in late 1999.
The hydrolic pressure is lost after it spouts off fluid. When you shut it off and restart the car will go with no problem. any ideas or suggestions?
Thanks Gretchen and Randy Gladfelter
Jan 22, 2008 at 3:01 PM
