2000 BMW 323 removing the expansion tank?
2000 BMW 323
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
NORCAL001
My current expansion tank has a crack on the side and looking to replace it. i found a replacement online but trying to remove it i found four connections removed three connections but one & the only one that is holding me up is the top main connection to the radiator. I pulled the retaining clip but i don't want to pull to hard should it just pop out or is their something more involved ?
Thanks in advance!
Oct 18, 2008 at 4:29 PM
JNOVACK
  • 723 POSTS
it is a rubber hose all you have to do is turn it and pull at same time
Oct 18, 2008 at 5:09 PM
DOCHAGERTY
  • 9,603 POSTS
Pull the clip and from both sides of the fitting, gently apply pressure with a couple of screwdrivers and it should pop off.
Oct 18, 2008 at 10:25 PM
