2000 BMW 323 Expansion Tank
2000 BMW 323
SMARTEEE
Engine Cooling problem
2000 BMW 323 6 cyl Four Wheel Drive Automatic
Repalcement of the expansion tank
Nov 8, 2008 at 8:43 AM
DAVE H
  • 13,384 POSTS
could you please explain what the exact information you require for this procedure is ??
Nov 8, 2008 at 9:31 AM
SMARTEEE
I have a 2000 BMW 328i. The expansion tank cracked. I am having a problem geting it unhooked at the bottom. Something is holding it on. I have unhooked 2 connections at the bottom, but the one that is connected to the T is where the problem is. Any suggestions?
Nov 8, 2008 at 8:25 PM
DAVE H
  • 13,384 POSTS
if i remember rightly once you have removed the bolts/screws .. the only way it is held on is by the plastic hooking over the readitor ? try pulling the tank upwards and outwards at the same time ..ohh and there is also a rubber seal where tank goes into radiator ..
Nov 8, 2008 at 9:11 PM
