2000 BMW 323 2000 bmw 323i (Hazard light & lock/unlock
2000 BMW 323
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
NART40
Hi:
I have changed bulbs all around the car from outside which most were LED. i noticed the light on dash for wrong bulbs. then i noticed that the signal light is faster than when i had the standard bulbs. Then, i noticed that the hazard button does not work along with the lock/unlock buttons which are next to each other.
Therefore, i changed all the bulbs back to the standard bulbs. however, the buttons are not working still!!!
i have checked all the fuses under the glove compartment but all were fine.
what is the problem? is there any other location with fuses i can check in the car? pls i wanna know how to fix this problem?
Aug 21, 2010 at 7:31 PM
DOCHAGERTY
  • 9,603 POSTS
The general module is suspect, it controls those functions. A trip to the BMW repair facility that you have chosen might be the next thing to do, it might require a short test with the proprietary BMW software to see where this problem lies.
Aug 22, 2010 at 9:37 AM
