Hi:
I have changed bulbs all around the car from outside which most were LED. i noticed the light on dash for wrong bulbs. then i noticed that the signal light is faster than when i had the standard bulbs. Then, i noticed that the hazard button does not work along with the lock/unlock buttons which are next to each other.
Therefore, i changed all the bulbs back to the standard bulbs. however, the buttons are not working still!!!
i have checked all the fuses under the glove compartment but all were fine.
what is the problem? is there any other location with fuses i can check in the car? pls i wanna know how to fix this problem?
Aug 21, 2010 at 7:31 PM
