On the way home from work yesterday, I used the right turn signal and it will not stop blinking. I turned the car on an off several times, but nothing affected it.
If I use the left turn signal, the right one will stop only while the left signal is on, then the right starts blinking again.
When I use the flashers, they appear to work correctly. When you shut the flashers off, the right blinker stays on.
May 4, 2008 at 7:49 AM
