2002 BMW 320 burns oil and smokes excessively
2002 BMW 320
80,000 MILES • 4 CYL • 2WD • MANUAL
DAVE1823
Hi
my bmw uses a lot of oil, seems to get to min with in a wk of filling, there are no leaks, also sometimes when car has been idle then i drive off there is excess smoke from the exhaust but seems to clear after a bout a mile.
thanks
Dave
Jun 30, 2010 at 1:02 AM
RACEFAN966
  • 5,029 POSTS
Ok sorry to say this but the engine in your car is tired. It is time to probably either rebuild or replace the engine. I would do a compression test first off one dry test and one wet test. I really think you are going to find out that it is the engine.
Jun 30, 2010 at 10:56 AM
DOCHAGERTY
  • 9,603 POSTS
Oil consumption is possibly due to a faulty pressure regulator or its associated plumbing. At the mileage reported the failure of the pressure regulator is quite common. Check this link out, it is quite helpful: http://www.realoem.com/bmw/showparts.do?model=EV13&mospid=47717&btnr=11_2194&hg=11&fg=15
Jun 30, 2010 at 5:06 PM
DAVE1823
Hiya
Thanks for your answers, would that be the fuel pressure regulator? or is there an oil pressure regulator. would like to try this first before rebuilding the engine. thanks Dave
Jul 1, 2010 at 12:28 AM
DOCHAGERTY
  • 9,603 POSTS
Dave, click on the link and see the part. It is not an oil or fuel regulator, it is a separator for oil vapor. It condenses the vapor back into oil and sends it back into the crankcase, and the leftover vapor is pulled into the intake manifold and consumed by the engine. Rebuilding the engine isn't needed, BMW motors are known for their robust engineering, at least internally, lol.
Jul 1, 2010 at 12:34 AM
