i bought a beamer last year high milage but it drives fine had a problem with over heating since i got it but unly when stuck in traffic been sorting things out slowly and the car only goes 20miles up the motorway to work each day no probs looses small amount of water each week but i cant find a leak any where the other day i was stuck in traffic when the temp went up so i pulled over lifted the bonnet
there was water in the expansion tank part of the radiator spits and spats of water\steam comming out of the radiator bleed screw you use this when topping up the radiator the top hose was solid preasure but nothing in the hose the other side of the thermos stat housing
also i recently replaced the thermostat or should i say put one in as there wasnt one in there did some one try to hid a problem do you think
Apr 8, 2008 at 3:29 PM
