Engine Mechanical problem
1993 BMW 320 6 cyl Two Wheel Drive Manual
I'm stationed in Italy and own a euro spec '93 BMW 320i (w/ VANOS). I was on my way to dinner the other night when the car started bucking and then stalled. It wouldn't start back up at all even after waiting 30 mins. So I had it towed home.
A friend and I starting digging into the next day to see what the deal was.
-I removed the back seat and listened to the fuel pump. I can hear it priming and feel fuel.
-I disconnected the supply line to the fuel rail and tried start it to see if gas would come out and it did
-I shot the wires to the fuel injectors and and they pulsed during a start attempt (which i'm taking is good)
-I hooked up a spark tester to the plugs and we got spark on all plugs
-I checked the compression as best I could (eng was cold) and it was good
-I took out the cover plugs to the cam shaft and checked the timing chain to see if it was loose or broke but it was good.
The car turns over fine but just won't fire up. So my buddy has 3 theories:
1. Bad Gas
2. Bad Camshaft Sensor
3. Bad Crankshaft Sensor
PLEASE HELP!!! I'll take any suggestions!
1. Bad Gas
Nov 10, 2008 at 6:07 AM
