1992 BMW 320 No clutch
1992 BMW 320
100,000 MILES • 4 CYL • 2WD • MANUAL
DUNDAGLAN
I bought an old 92 320i BMW a few weeks ago. The other day i drove it and everything seemed fine. Next morning the clutch was gone/dead/no pressure/lifeless.
I'm not too experienced on engines but had a look inside - the breke fluid seems fine ie its at the correct level. Not sure if there is a seperate clutch fluid? In anyways any ideas what happened and what i need to fix it?
Regards
Dec 9, 2008 at 10:31 AM
DOCHAGERTY
  • 9,603 POSTS
It sounds like the clutch master/clutch slave cylinders are in need of replacement. Although the master is probably the one that failed, I would inspect the slave and if there were any doubt it would get replaced as well. The brake fluid reservoir is the clutch fluid reservoir as well.
Dec 9, 2008 at 11:04 AM
