95 318i Abs Light
1995 BMW 318
CRNA1AB
  • 4 POSTS
My abs light is on...any suggestions...Thanks in advance!
Sep 22, 2007 at 12:40 AM
DOCHAGERTY
  • 9,603 POSTS
you will have to have the fault memory read out
this will help guide the diagnostic
for example, the brake fluid level being low could command the ABS light on
repost and keep in touch
Sep 23, 2007 at 11:10 AM
BURROWSSJ
i read that it could be the sensor in the brake failing or could mean your abs is disabled i even heard that some voltage problem with 318's can cause this? i have the same problem, I am going to get it checked.
Nov 18, 2008 at 2:06 AM
