1996 BMW 318 FUEL PUMP FUSE
1996 BMW 318
150,000 MILES • 4 CYL • 2WD • MANUAL
SAM KHOURIEH
MY FUEL PUMP FUSE KEEPS BLOWING INSTANLY WHEN CAR IS STARTED I AM WANDERING IF ITS A SHORT IN PUMP ITSELF OR IN WIREING ?
Aug 14, 2008 at 8:39 AM
KHLOW2008
  • 41,814 POSTS
Hi Sam,
Don't wander too far away.
Unplug the fuel pump connector and test if the fuse blows, yes mean wire, no means pump is shot.
Aug 14, 2008 at 10:00 AM
DOCHAGERTY
  • 9,603 POSTS
It's the fuel pump, E-36 are notorious for failing fuel pumps at the mileage you stated. It is under the rear seat on the right side. Pop the rear seat bottom up and unscrew the big ring (I use two crossed screwdrivers and catch the little tabs on the ring, turn it slowly and it will unscrew) and replace with part#16-14-6-758-736
Aug 15, 2008 at 12:10 AM
