Engine Performance problem
1994 BMW 318 4 cyl Two Wheel Drive Manual
when i start up my car it idles between 3500 and 4000. I have replace the mass air flow sensor, throttle positioning sensor, checked for leaks and even disconnected the throttle cable. The car had a fuel leak and it idled at maybe 800. soon as i fixed the leak the idle when up. i disconnected the negative battery cable to see if the engine would reset itself and still the same is happening. all fuses are good. what should be the next I could do?
Jul 18, 2010 at 3:12 AM
