Engine Cooling problem
1991 BMW 318 4 cyl Two Wheel Drive Manual
91 BMW 318i. I not long ago replaced my radiator, water pump, and thermostat with all of the necessary gaskets and seals. I've noticed my coolant level creeping lower and lower after a while and I can't find any puddles, white smoke, or coolant in the oil. I need to replace my valve cover gasket and fan clutch but I'm not sure if either of them would cause a leak. Would you have any ideas as to where it could be going? Any help would be greatly appreciated.
Jan 7, 2010 at 1:36 PM
