1990 BMW 318 water pump
1990 BMW 318
200,000 MILES • 4 CYL • 2WD • AUTOMATIC
SMILEY64
I have undone all the bolts how do I pull the water pump out?
Aug 22, 2009 at 12:39 AM
DOCHAGERTY
  • 9,603 POSTS
I am going to assume you have a new pump in hand. As you hold the pump, look at the four holes that the mounting studs will protrude through, there are two threaded holes at the sides, these are for removal purposes. Thread two 6x1.00x30mm bolts into these to push the pump away from the timing cover, and off it comes!! ♥
Aug 22, 2009 at 9:03 AM
