REMOVING AND INSTALLING STEERING LOCK/IGNITION SWITCH :
*Disconnect battery ground lead.
*Remove steering wheel.
*Remove instrument panel trim at bottom left.
*Remove lower steering column casing section.
*Press in hooks on both sides toward ignition switch and pull out the ignition switch.
Installation :
*Check position between ignition switch and steering wheel lock!
Jan 13, 2010 at 12:38 AM
