1985 BMW 318 ignition switch
1985 BMW 318
130,000 MILES • 4 CYL • 2WD • MANUAL
MATER420
how do you change the ignition switch
Jan 12, 2010 at 11:36 AM
REMOVING AND INSTALLING STEERING LOCK/IGNITION SWITCH : *Disconnect battery ground lead. *Remove steering wheel. *Remove instrument panel trim at bottom left. *Remove lower steering column casing section.
https://www.2carpros.com/forum/automotive_pictures/12900_ignition_1.jpg
*Press in hooks on both sides toward ignition switch and pull out the ignition switch. Installation : *Check position between ignition switch and steering wheel lock!
Jan 13, 2010 at 12:38 AM
