1985 BMW 318 Fuel delivery problem
1985 BMW 318
BIGBUCKHAGAN
Engine Performance problem
1985 BMW 318 4 cyl Two Wheel Drive Manual
Vehicle starts, runs about 8 seconds then cuts off and on then recovers and runs fine until parked for a few hours. I replaced the fuel filter, no change. The vehicle acts as though air gets in the fuel line, does some sputtering until the line is solid fuel again. It started about 3 weeks ago and seems to be getting worse.
All help is appreciated .
Jun 18, 2010 at 8:03 PM
DOCHAGERTY
  • 9,603 POSTS
Does this occur when the fuel tank is completely full? There is a internal fuel transfer pump in the tank, but it only helps move the fuel to the main pump when the level is low. Check this site: http://www.realoem.com/bmw/showparts.do?model=1374&mospid=47315&btnr=16_0046&hg=16&fg=05
Jun 19, 2010 at 10:39 AM
BIGBUCKHAGAN
Full or not it is consistent.Took off this morning went 4 miles and parked vehicle for 15 minutes.Restarted vehicle and took off, when I reached 3rd gear motor was intermittently sputtering, hit 4th gear a few sputters then everything is fine. Fuel tank is full. While vehicle was idling I placed my fingers around the discharge side of the fuel line about 4 " from the fuel pump and could feel intermittent turbulence. Without access to a fuel pressure gauge I have to suspect a failing pump. Car runs fine after it gets over the initial sputtering phase.Thanks for the response .
Jun 19, 2010 at 1:01 PM
DOCHAGERTY
  • 9,603 POSTS
Diagnosis of fuel pressure issues should include a waveform analysis, maybe the pump is not getting power.
Jun 19, 2010 at 1:25 PM
