2000 BMW 316 odometer fuel gauge and speedometer not workin
2000 BMW 316
94,000 MILES • 4 CYL • 2WD • MANUAL
MEXICANITCH
I left my car in a garage I trust for fitting foglights in. He had to do the whole wireing and all. He said when removing and reinserting the instrument panel (for fitting a small light behind the dashboard which tells me the fog lights are on) he experienced that the speedo,- odo-meters and the fuel gauge stopped working. Checked all the fuses, fine. Sent it to specialist, and got the answer that the CPU of the instrument panel is forzen. It was all his fault, even if he has done his best. he doesn't really know the solution and I want my car back asap. What might be a solution? New dushboard, or how would be possible to fix the old one? Many thanks for your answer.
Oct 27, 2008 at 5:39 AM
DOCHAGERTY
  • 9,603 POSTS
If the instrument cluster has failed internally, then I would have the cluster replaced at his expense.
Oct 27, 2008 at 11:13 AM
