How do I navigate to Bluetooth settings?
2023 CADILLAC ESCALADE
20,000 MILES
CARGAMER
It’s this stupid voice activated thing.
Aug 12, 2023 at 8:30 PM
Please note that interface designs can vary between car models and years, so it's always a good idea to consult your vehicle's owner's manual for the most accurate and up-to-date information. Here's a general guide on how to navigate to Bluetooth settings:
Access the Infotainment System: Turn on your 2023 Cadillac Escalade's ignition and access the vehicle's infotainment system by using the touchscreen display on the center console.
Home or Main Menu: Depending on the infotainment system's layout, you might need to find the "Home" or "Main Menu" button/icon on the touchscreen. This is usually where you start navigation through various system options.
Settings: Look for a "Settings" option on the main menu. It might be represented by a gear icon or labeled as "Settings" or "Options."
Connectivity or Bluetooth: Within the "Settings" menu, you should find an option related to "Connectivity," "Bluetooth," or something similar. Select this option to access Bluetooth-related settings.
Bluetooth Settings: Once you're in the Bluetooth settings section, you might see options such as "Pair Device," "Manage Devices," or similar terms. These options allow you to pair new devices, manage previously paired devices, and adjust Bluetooth-related settings.
Pairing a Device: If you're looking to pair a new device, there should be an option to "Pair Device" or "Add Device." Follow the on-screen instructions to initiate the pairing process, which usually involves making your device discoverable and selecting it from the vehicle's Bluetooth menu.
Managing Paired Devices: If you're trying to manage existing paired devices, you might see a list of devices that have been connected before. From here, you can select a device to modify its settings, remove it, or initiate a connection.
Aug 14, 2023 at 12:32 PM
