Blue smoke problem when pressing accelerator
2005 VOLKSWAGEN GOLF
175,000 MILES • 1.4L • 2WD • MANUAL
KHAMZENE MONARE
Blue smoke and petrol smelling while engine running.
Nov 5, 2018 at 8:11 AM
It sounds like you may have the oil drain back holes plugged in the cylinder head. I would remove the valve cover to inspect. Here are two guides to help us get started:
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
and
https://www.2carpros.com/articles/replace-valve-cover-gasket
Nov 6, 2018 at 11:07 AM
KHAMZENE MONARE
My car is Mk1 velociti 1.4i. Do you mean the answer could be the same?
Nov 16, 2018 at 12:10 AM
Yep, if the oil changes have not been done on time it can cause sludge clogging up the holes.
Nov 16, 2018 at 1:23 PM
