My truck c-1500, new injectors, new cam and crank sensors, new plugs, wires, cap,rotor. one new o2 sensor rear one farthest back.
Truck starts very easy-idle smooth-good acceleration. Dose not hesitate it actually runs better now than when I bought it new. After major tune up.
Now to problem there is no smoke on start up or while driving. If you stop at red light foot on brake for very long starts puffing blue smoke and will continue while driving. If you shut ignition off and start right back smoking stops completely. It might be a day or two before smoking again. Or the next light no steady pattern. You must turn key off then restart to reset whatever or it will smoke like crazy until you do. But once you do there is no smoke at all. It's got me baffled all codes have been addressed and not showing any codes no engine light on either. Can you shine any light on this?Acts like sensor of some sort to me because of the key reset thing. It is listed above C1500, extended cab, LT. New four speed automatically transmission M30 4L60E.
Mar 15, 2019 at 8:01 PM
