Blows hot air from driver side top A/C vent. All other vents blow cold air, but pressure is not up to the limit. replaced heater core assembly with used one. and bypassed the duo valve by connecting the heater hose with water pump. replaced Climate Control Vacuum Valve Block with used one but, now all vents blow hot air. Sometimes there is noise due to air leaking around the block (not all the time). removed the battery and reconnected after 30 minutes then it's works fine sometimes. Looking forward to some solutions.
Thank you.
Thank you.
May 7, 2024 at 4:25 AM
