Blown main fuse
1999 HYUNDAI TRUCK
170,000 MILES • 6 CYL • 4WD • AUTOMATIC
JENNDONNELL
Every time I connect my battery cables it blows the main fuse. please help, I am so frustrated.
Jul 10, 2016 at 4:31 PM
WRENCHTECH
  • 20,761 POSTS
Are you sure you do not have one of the small battery cables hooked up the wrong terminal. You have a direct short to ground somewhere. If you cannot find it try disconnecting the alternator.
Jul 10, 2016 at 4:59 PM
JENNDONNELL
That may be the problem. There are two cables that are connected to the negative terminal. The negative cable it the first picture and the positive has four wires coming from it.
Jul 10, 2016 at 5:08 PM
WRENCHTECH
  • 20,761 POSTS
I cannot tell where they are all connected. Make sure nothing from the positive side is touching ground.
Jul 10, 2016 at 5:12 PM
JIS001
  • 3,412 POSTS
As WRENCHTECH has suggested, Disconnect the alternator and then connect the battery cable to see if the fuse blows. If it stops blowing then replace the alternator. Do the same thing with the starter and trace positive battery cable to make sure it is not rubbing anywhere.
Jul 11, 2016 at 11:15 AM
