Okay. So, if this the same fuse, then that makes it number 4 in the IP fuse box?
If that is the case, then that is a pretty large circuit as there are a lot of components on it.
So, it could be a wire as stated above or it could be any of the components circled. The best thing to do is try and eliminate these items one at a time and if the fuse keeps blowing then move onto the next one.
However, this is when the fuse blows immediately. Since you have to drive it a little way, you may be better off disconnecting all of them and confirm the fuse stops blowing. If it does, then plug one back in at a time until it blows again.
If the fuse blows even with the things unplugged, then you have a wiring issue.
Sorry about the diagrams. I tried to enlarge them
Dec 19, 2021 at 7:03 PM
