Hi Mary,
I wish there was an easy way, but it is somewhat of a big job. You can't just remove the cylinder head to replace the gasket. Instead, the top of the engine needs to be removed to access the head bolts. Additionally, the timing chain will need removed and the camshafts. The camshafts block the cylinder head bolts. That's why they need to be removed.
Okay, I attached all the directions in the order I feel you will need below. It starts with the removal of the intake manifolds (both upper and lower). Then to timing chain removal and replacement (it's very important that you have the timing correct before trying to turn the engine). Last is cylinder head removal.
Because of everything that needs to be removed, I would recommend replacing both head gaskets, but that's up to you. Also, the timing chain info indicates the removal of the crankshaft gear. I don't feel that will be necessary, but when you get to that point, let me know if you need help.
Let me know how things turn out for you or if I can help in any way.
See pics below.
Mar 13, 2022 at 7:11 PM
