Hey Ryan,
There's actually a number of potentials. There's much talk about the fuel management system that creates excessive oil use, plus - bad PCV valves, bad rings, worn cylinder walls, bad valve guides and/or seals, blown head gasket, intake gasket issues, hole in piston, massive blow-by pushing oil through vacuum lines via the intake, and I'm sure there are more.
With as fast as you are losing oil, you obviously have one, or more, issues. Below is one of our Repair Guides. I hope this helps.
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Any engine codes, have you done a compression check, and how quick did this become an issue (slowly, or all of a sudden)??
Much luck. Glenn
Mar 9, 2021 at 9:35 PM
