Okay, I am not the sharpest in the shed.
The PCM, ASD fuse blows when I turn the key. Not the TCM fuse as I described in my earlier post.
I tried the placing spades to the fuse space with a twelve volt bulb attached between the two LED's. The bulb was very dim. I used a twelve volt test light between the LED's. Do you have any other suggestions for me to try? I thank you for your time.
Sep 30, 2017 at 1:47 PM
