If you think an injector is shorted, as never actually happens, just unplug them. That would remove the short from the circuit.
You've wasted so much time and fuses, it would be much less costly if you have an electrical expert look at it. This diagnosis with my light bulb trick should take the better part of ten minutes.
I've had a tail light fuse blowing when driving over bumpy roads, on a full-size Dodge van, and an intermittently overheating engine on a mid '90s Caravan, both solved within minutes of plugging in a test harness I made from a Viper tail light harness. I made that tool by soldering the harness to a blown fuse that could be quickly plugged in, in place of the blowing fuse. Depending on how much current the circuit normally required, I could plug in up to three bulbs into that harness, with a total of five filaments. You don't have to get that involved unless you expect to have use for this in the future. A single bulb with two spade terminals and a pair of jumper wires will work just fine.
The clue to the overheating engine was the radiator fan relay was on the same circuit as the back-up lights, and the owner never noticed the back-up lights had stopped working. With my test harness clipped into the circuit in place of the very hard-to-replace fuse link wire, the back-up lights worked, but dimly, as expected, indicating no short was present. As soon as I tried to accelerate to back out of the stall, the test light turned bright and the radiator fan stopped running. The only way to make the short appear was to force the engine to rock when backing up. The fat wiring harness that runs under the battery tray was sliding back and forth for years, and the insulation on some wires had been rubbed bare, along with the paint on the inner fender. How are you ever going to find that by just continually throwing new fuses at it? In this case it was multiple fuse link wires that are spliced and soldered in, and are very time-consuming to replace.
The tail light problem on the van turned out to be an added-on trailer wire harness wire was caught under the left rear lens and the insulation got crushed when the screws were tightened. I had the test light harness hooked over the rear-view mirror so I could see it easily. This one took less then 15 seconds to find with a rubber hammer. Ten of those seconds were spent walking over to my tool box to get that hammer. It just took a light tap on the lens to make the short appear. The only other way to find that would have been to have a helper drive the van over bumpy roads while I ran along behind it. I'm too old and slow for that!
Oct 22, 2019 at 6:48 PM
