blown fuse
2002 SATURN SL2
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
PAUL LINDSEY
I keep blowing a number ten fuse in the fuse panel located next to passenger left leg. it controls the dome light and drivers door key-less lock/unlock. when I replace the fuse it does not blow right away it works for a few days then it will blow. i am stumped as to what could possibly be blowing it. phone charger?
what can I look for?
May 28, 2017 at 4:06 AM
SATURNTECH9
  • 30,869 POSTS
Is the fuse labeled locks? Or is it labeled body?
May 28, 2017 at 2:57 PM
PAUL LINDSEY
body.
May 28, 2017 at 5:31 PM
SATURNTECH9
  • 30,869 POSTS
The cigarette lighter is a different circuit the body fuse is the trunk release dome light part of the door lock circuit etc. If you have a sunroof that is part of it as well as power mirrors. I have seen a lot different things blow that fuse pinched wire on the passenger mirror pinched wire in the trunk hinge pinched wire in the sunroof module etc.
May 28, 2017 at 7:23 PM
PAUL LINDSEY
no sunroof or power mirrors..so maybe look for a pinched wire in the trunk latch?
May 29, 2017 at 3:29 AM
SATURNTECH9
  • 30,869 POSTS
Could be, I have seen that on the drivers side where it was ran under the trunk hinge.
May 29, 2017 at 6:40 AM
