Blowing the cigarette and radio fuses?
1990 SUZUKI SIDEKICK
189,000 MILES • 1.6L • 4WD • MANUAL
LHARMON207
Hello, so while driving my vehicle listed above just quit running after inspecting, I found a fuse was blown and it was the cig radio fuse I replaced the fuse and about two blocks later it died again and now won't start or even turn on without blowing that fuse again?
Jun 7, 2024 at 9:32 PM
I would remove the cigarette power wire because they can go bad or look inside the lighter using a flashlight near the bottom to see if there is a coin inside of it. This is common, please let me know.
Jun 8, 2024 at 11:40 AM
LHARMON207
Already did that I disconnected both the lighter and the radio and it's popping the fuse before I can even get it in.
Jun 8, 2024 at 7:37 PM
Can you look under the dash to see if any of the wiring has been damaged? Also, what is the condition of the fuse panel? My source does not show the wiring diagrams for this car, sorry.
Jun 10, 2024 at 10:27 AM
LHARMON207
Yes, I pulled the steering wheel and dash off no wiring looked damaged I had an oil leak so I cleaned every ground I could find and I disconnected the starter and alternator and it still blows that fuse as soon as the key goes to on its driving me crazy..
Jun 10, 2024 at 1:53 PM
STEVE W.
  • 15,113 POSTS
Is it the 40 amp fuse link or the 20 amp in the fuse box for the cigar lighter & radio that blows? Both of those were optional items connected to a White wire with Black stripe that comes out of the fuse block. If it kept blowing and now it won't start I would check the 40 amp fuse link under the hood. If it blew it would shut off the other power as well.
Then to find the short in the radio harness I would get either a short finder or a fox and hound unit and use those to check the wiring. My suspicion is that the harness is shorted inside the tape at one of the places it is fastened. Saw that on one I had. The wires inside the harness chaffed at the splice where the radio and lighter harness was attached.
Jun 10, 2024 at 5:11 PM
The wiring sounds like it is shorted to ground, I would try repairing the wiring while looking for the problem to help confirm the fix.
Jun 10, 2024 at 5:12 PM
