Keeps blowing the ignition fuses, why?
2006 CHEVROLET EXPRESS
150,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
TRULY87
I I have the vehicle listed above 3500 cutaway van. The ignition fuses keep blowing can off powertrain transmission. Module fuse blows once put in fuse box sometimes don’t blow until car is cranked this thing down all power to the powertrain which is the transmission send it into limp mode, once this happens transmission is stuck in second gear I don’t know where to look at for short to ground if possible is number fuse number six in the fuse box, ignition fuse, which controls, PCM,ECM.
Jun 1, 2023 at 8:37 AM
If a fuse keeps blowing, it's typically a sign that there's an electrical short somewhere in the circuit that the fuse protects. In your case, if it's the ignition fuse that's blowing — a fuse that protects the circuits to the Powertrain Control Module (PCM) and the Engine Control Module (ECM) — then the problem lies somewhere in that circuit.
Here's a general guideline on how to find and fix the issue:
Find the Wiring Diagram: Your first step should be to find a wiring diagram for your vehicle, focusing on the circuit that's causing problems. This diagram will show you all the components that are protected by the ignition fuse, and it will give you a roadmap for tracking down the short. If you don't have a physical manual, you might be able to find this diagram online.
Inspect the Components: Visually inspect all of the components that are protected by the fuse. This includes the PCM, the ECM, the ignition switch, and any other related components. Look for signs of damage or wear, especially burned or exposed wires. If you find a damaged component, replace it.
Check the Wiring: If the components themselves seem fine, the problem could be with the wiring. Inspect the wires that connect the various parts of the circuit. Look for damaged or frayed wires, disconnected wires, or wires with exposed metal. If a wire is touching a part of the vehicle that's grounded (like the metal body of the vehicle), it could be creating a short.
Use a Multimeter: If a visual inspection doesn't reveal the problem, you can use a multimeter to test the circuit. Disconnect the battery and set the multimeter to the "ohms" setting. Connect one probe to the ground wire at one end of the circuit, and the other probe to the ground wire at the other end of the circuit. If the multimeter shows a very low resistance, that could indicate a short in the circuit.
Jun 2, 2023 at 7:31 AM
