my fan speed keeps blowing the ac fuse. it will run for a minute then blows the fuse
Mar 26, 2026 at 9:44 AM
CERTIFIED EXPERT
Will the fuse still blow if the heater is on? Also while the heater is on do you still have all fan speeds? if so I would unplug the compressor and turn the system on to see if the fuse still blows, if it doesn't then you have an AC compression clutch coil that is shorting out. Please give me more information to help you. Ken
