GM had a miserable problem in the late '80s that they handled very poorly. All of their steering gears developed "morning sickness", meaning loss of power assist, but only in one direction, and only for the first ten or fifteen seconds in the morning. Once the power steering fluid warmed up, the power assist came back. The problem got worse and worse over the next few weeks, then the loss of assist affected turning the other way too. If ignored long enough, the power assist would never return.
GM came up with a "fix" for this that involved replacing the spool valve assembly from under the dash. Their contention was the four Teflon sealing rings were wearing down, then pressurized power steering fluid could bypass the power piston rather than push on it to help you turn the steering wheel. In fact, the new valve did solve the problem, . . . for a little while. The goal of the repair was to get the vehicle out of the 50,000 mile warranty, then, when the problem returned, it was up to the owners to pay for the proper repair.
It wasn't really the Teflon rings that were wearing down. They were wearing grooves into the soft aluminum housing the valve sat in. Installing a new valve with new rings on it didn't address the grooves. It took a major aftermarket supplier, Moog, to develop the effective repair. That was to bore out the housing and press in a stainless steel insert, or liner. No more loss of power assist problems. Other manufacturers, to my knowledge, didn't have this problem, but when you get a Moog replacement rack assembly, they have the same liner installed.
The next problem has to do with the power steering pump. Those cause very little trouble on any car brand, except for one pump called the "ZF"-style pump. The best I can describe it is it is very small and has four bolts on back in a square pattern. Those developed worn vanes and lost their ability to push fluid under very high pressure. Your pump looks similar, but it doesn't have those four bolts. Your vehicle is a little newer than the vehicles that had this problem, so if it is related, I'd assume the worn vane issue had been addressed long ago.
The third thing has to do with variable-assist power steering. Supposedly this is supposed to reduce the amount of assist at highway speeds to save fuel or provide more road feel. Regardless, now there's another unnecessary and complicated computer module and valve involved. On Chrysler products, that valve and a small module are mounted right on the rack and pinion assembly, next to the spool valve / steering shaft. I do not see that on yours, and I don't see any reference to that valve being on a hose, in the pump, or anywhere else, so we'll ignore that for now. By the way, that system is diagnosed with a scanner through the Transmission Computer. It knows road speed so it knows when to deactivate the power assist.
That leaves a weak pump and internal leakage inside the rack and pinion assembly as the two suspects. There is a tool to figure out which one is the culprit, but I've never seen it available anywhere except as a special tool supplied by the manufacturer to their dealerships. It's a short metal pipe with a pressure gauge and a shut-off valve. You remove the high-pressure hose from the pump or the steering gear, then install the test gauge and hook the high-pressure hose to the other end. With the engine running, you close off the shut-off valve very briefly, then reopen it. During the couple of seconds it's closed, you watch the gauge to see how high pressure goes. As I recall, the minimum acceptable pressure was 1100 psi, with over 1200 psi being normal. If the gauge instantly jumped up that high, it proved the pump was capable of developing the required pressure. That left the steering gear as having suspected internal leakage. If there was no leakage, fluid pressure would still be very high with the test valve open.
If closing the test valve resulted in less than 1100 psi, the pump was the suspect. It could take an hour or more to install the test fixture, but that was better than guessing and replacing the wrong part. Some rack and pinion assemblies, such as on the Dodge Dakota, take 0.3 hours to replace, so it's not a big deal, . . . if you have a replacement at hand. If you have to order one or buy it from an auto parts store, you'd rather know for sure you're buying the part you need. Some models have two dozen pages of instructions for replacing a steering gear, and for many others, it isn't much better for the pumps, so you want to be right. Some Ford models call for over four hours to remove the steering gear, including raising the engine. You really want to be right on those.
I realize these comments aren't helping you solve this problem, but what we should do is start a new question related to just the loss of power assist. These questions get categorized according to type of problem to make it easier for others researching the topic to find related articles. This will show up under electrical problems and won't help anyone with power steering problems. The other issue is there is often something very common that I'm not aware of, but one of our other experts is. Unlike on other sites where anyone can chime in to confuse the issue, here, as soon as I posted my first reply, this became a private conversation between just the two of us. As such, none of the other experts will see this new problem or have the chance to reply. That may not get you the best help for this problem.
Here's the link to start a new question:
If I see it, I'll click on my link to follow along and learn the solution, but I already added all of my wisdom on this topic here, so I'll let one of the other experts become involved. I'll still offer comments of value if I have any.
Oct 7, 2023 at 7:50 PM
