blowing blinker fuse
1991 TOYOTA PREVIA
440,000 MILES • 2WD • AUTOMATIC
PIGLETRMA
  • 8 POSTS
First, I had my left side blinker blinking faster than the right (and all blinkers were lighting up) then it started blowing fuses as soon as I turn either blinker on. I disconnected the trailer harness to eliminate that possibility. Same problem.
Mar 20, 2020 at 8:13 AM
Good morning,
Were any bulbs changed recently? If the wrong bulb was installed, it will do this.
Do all the other bulbs work as commanded?
Do you have a test light or volt meter to do some checks?
Mar 20, 2020 at 8:18 AM
PIGLETRMA
  • 8 POSTS
I do have a voltmeter. No bulbs recently changed.
Mar 20, 2020 at 8:36 AM
Do all other bulbs work normally?
Mar 20, 2020 at 8:43 AM
PIGLETRMA
  • 8 POSTS
yes, brakes and taillights seem to be fine.
Mar 20, 2020 at 8:46 AM
I attached a picture for you. The connector I circled, please disconnect it and see if the fuse still fails.
The connector is at the bottom of the steering column.
Mar 20, 2020 at 8:53 AM
PIGLETRMA
  • 8 POSTS
okay, this is weird, but may help. I removed all bulbs. I ran out of 7.5 amp fuses so put a 20 in (I know, not for long) with all bulbs out, when I turn on either right or left I get a squealing noise from the dash.
Mar 20, 2020 at 8:58 AM
PIGLETRMA
  • 8 POSTS
okay, I will disconnect that. thanks!
Mar 20, 2020 at 9:00 AM
Okay, remove it. By doing that, you are overheating the circuit and can cause wiring harness melt down.
You never, ever install a larger fuse than required as you can cause more issues.
Mar 20, 2020 at 9:01 AM
Keep me updated.
Mar 20, 2020 at 9:04 AM
PIGLETRMA
  • 8 POSTS
dang. That is going top take some dash surgery to even see that. I will get back when I succeed. Thanks
Mar 20, 2020 at 9:05 AM
Sounds good.
Mar 20, 2020 at 9:13 AM
PIGLETRMA
  • 8 POSTS
Well, I only had it in for a second . Just long enough to hear that noise. What do you think that buzzing was coming from? I have heard it buzz in the past from time to time, but it always went away.
Mar 20, 2020 at 9:55 AM
Sounds like it could be a short in the harness.
Mar 20, 2020 at 9:56 AM
Another suggestion. I would go to a part store and get a self resetting circuit breaker of the correct amperage so you do not have keep replacing fuse to determine the issue.
Mar 20, 2020 at 1:04 PM
PIGLETRMA
  • 8 POSTS
Turns out it was the flasher!
Mar 20, 2020 at 5:01 PM
Good find. We were not there yet but would have got there.
Good find. Glad it is fixed.
Mar 20, 2020 at 5:08 PM
