Blowing a little bit of white smoke
1998 HYUNDAI EXCEL
MANUAL
ITALIANA
i drive a manual excel lately my car has been blowing a little white smoke whenever i rev the engine even when its not hot weather it still seems to blow a little white smoke. i gave the car a little service i replaced the spark plugs and oil and all that stuff not sure if this is a bad thing or something little ? i haven't used my air con also in a while i put air con on could that be the issue
Oct 18, 2015 at 11:08 PM
MHPAUTOS
  • 31,937 POSTS
You should go get a head check done, this is a simple chemical test to check for Co in the cooling system, if positive result you will have a head problem.
Oct 19, 2015 at 5:36 AM
