When I crank my engine the 15 amp main fuse blows if I pull the main relay the fuse will not blow I have disconwcted the ecu and the fuse will not blow that looks like where the wire is going to could it be bad ecu they rarely go out or could it be wiring that goes through the ecu out to something else
Dec 28, 2015 at 4:51 PM
